squish on T5 malossi 172kit
Tosh
when i striped the scoot down to change the main oil seal i noticed that there was no head gasket and i didn`t check the squish, i`ve now got all my new parts to start the re build but was wondering if i should put the new head gasket on or leave it off if the squish is correct,and do i check it like when i`m sorting the lammy out,through the plug hole or as i do put plasticine on top of the piston,
H,POOL GADGE
Main scooter: vespa polini220/gts 300
no worries gadge! repair and rebuild your engine, put head on as it was without gasket and check the squish, with a cross of plasticine across piston crown or soldier through plug hole, then you,ll know if it needs the gasket or not....
Tosh
thanks H,POOL GADGE for that, what size of squish am i looking at please.
Paul
H,POOL GADGE
1.2mm
Tosh
thanks again, an safe riding
    Users browsing this forum: Google [Bot] and 9 guests
