ts1 gp200 20/46
martinr
anybody running ts1 with gp200 box and 20/46 sprocket .im running 19/46 now but feel like im running out of gears first and second are very short
bazman
What's 4th like ? 1st and 2nd on a ts1 you're through them very quick anyhow!! What's your set up ?
willwander
I would have thought 20-46 would be very long, unless you have a very good TS1 or maybe an ADS3.
standing mile: 118.6mph
martinr
set up is transfers matched ts 225 gp 200 box 19/46 franspeed stainless steel jl3 road tmx 35mm 300 main jet 20 idel 58 needle middle clip . 4th seems not to bad but i get to around 73 mph and thats it
20x46 on a GP box is only a 4.6 final drive. That's not high for a TS1, is it?
bazman
That should pull ok unless you're eh on the heavy side ...!!
I use 19/46 gp 200 box on my ts1 ( 4.8) i feel it's a good allrounder , only if you're doing a lot motorway miles would i personally change to 4.6 , nothing to lose trying though .
Dryballs
What chain would you run for 19 or 20 / 46?
    Users browsing this forum: Ahrefs [Bot] and 8 guests
