Which Exhaust?
dopeshots
Xbox live gamer tag: rms789
Main scooter: GP150
Hi all I want to get a new expansion exhaust for my Lammy but which one?
My set up is as follows:
GP150 with a 175cc AF stage 4 conversion (steel barrel)
30mm Dellorto on a MB manifold
Over the kickstart fresco at the moment.
I plan to upgrade to an RB Kit at some stage so would want the exhaust to work with what I have now and with what I will have in the future.
My only stipulation is that I want to run a full frame Lambretta without cutting down the side panel or footplate.
many thanks in advance ;)
CPH Lambretta
Main scooter: DL 150 1970
The simple answer is you can't.
The exhaust port on your stage 4 is totally different to the port on an RB.
So you will have to buy 2 exhausts, one for your 175 and another when you buy your RB. :(
Slow is the new fast!
ForemanBob
Main scooter: GP RT230
What's wrong with the Fresco? Are you wanting more top end?
What's your budget?
dopeshots
Main scooter: GP150
The Fresco hits the panel so I want to change it. Budget £300 tops.
Why not use a simple box pipe inside 100 quid on your stage 4 thing, and save the rest towards an expansion when you've finished your RB?
Bilko
Main scooter: LI150
Muttley McLadd wrote:Why not use a simple box pipe inside 100 quid on your stage 4 thing, and save the rest towards an expansion when you've finished your RB?
That's what I had at one time and would definately use again.
Bilko's Oily Blog
dopeshots
Main scooter: GP150
Found out from JB that the Franspeed Exhaust comes with different mountings so you just swap according to what the exhaust is going on.
So I bought one of those.
Russ :bouncyeng:
I might be wrong but I wan't aware these were compatible with RB :-?
Many pipes have different stubs for oval and round exhaust ports, but not RB as these are very different. As I say, I stand to be corrected but I'm not aware of a mounting that will cross over to RB.
