wich full circle crank should i use in a rb 22
ordered a tino one from a dealer (he sent me a used one) i sent it back, hes sent me another but ime not happy with it as i dont know who made it (wont use that dealer again)
so just wana know which one to go for ,dont realy wana spend 400 + on an mb alfa crank though
cheers jon
which crank ???
- wack 63
- Main scooter: '71 GP TS1
Try Corrado on here http://www.justlambretta.com/ .He had one for £220 on his stall at Kettering which looked good.
WINTERMODEL150
- Main scooter: lambretta ld auto
Have you tryed JB tuning?
- corrado
- Dealer
- Main scooter: Lambretta GP
Italian made with forged rod but it's a 60mm with 116 rod. Bought a couple for my own use with MB TS pistons for long rods.wack 63 wrote:Try Corrado on here http://www.justlambretta.com/ .He had one for £220 on his stall at Kettering which looked good.
eibargum
- Main scooter: Vespa PX210 Polini
Why not buy a Sil crank and have a Yam 110 rod put in, with a good bearing and a nice tight pin done buy somone who knows what there doing, ive a full circle race jobby in mine but if i were doing it again thats the way i,d go, also use a light,nd flywheel to give it a easy,r life.
shamrockexpress
eibargum wrote:Why not buy a Sil crank and have a Yam 110 rod put in, with a good bearing and a nice tight pin done buy somone who knows what there doing, ive a full circle race jobby in mine but if i were doing it again thats the way i,d go, also use a light,nd flywheel to give it a easy,r life.
I bought an rd250 rod kit to put in a 60mm set of webs only to discover the RD pin is smaller,,,
so what is the solution??????ANYBODY
eibargum
I,v had a crank [indian] done as a spare by Martin at Chiselspeed, RD400 rod i believe, i watched him do it and there wasnt a issue with the pin, 6 ton to push the pin inshamrockexpress wrote:eibargum wrote:Why not buy a Sil crank and have a Yam 110 rod put in, with a good bearing and a nice tight pin done buy somone who knows what there doing, ive a full circle race jobby in mine but if i were doing it again thats the way i,d go, also use a light,nd flywheel to give it a easy,r life.
joespeed
some indian webs are 22.9 yam rod is 22mm!shamrockexpress wrote:eibargum wrote:Why not buy a Sil crank and have a Yam 110 rod put in, with a good bearing and a nice tight pin done buy somone who knows what there doing, ive a full circle race jobby in mine but if i were doing it again thats the way i,d go, also use a light,nd flywheel to give it a easy,r life.
I Spoke to Mr Kemp about the cranks used on the RB, asking him what he would recommend, a full circle crank was not his first choice.
I remember Mr Kemp saying somthing along the lines of... if it's not in the crank case to start with, then how can it be drawn into the cylinder, best to fill the case with air and fuel rather than metal and let the pipe do it's best to fill the cylinder.
This was some time back.
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
J1MS wrote:I Spoke to Mr Kemp about the cranks used on the RB, asking him what he would recommend, a full circle crank was not his first choice.
LPC?
