Brake shoes
LI150
Main scooter: Series 2 LI150
Juat built a 200 engine using a 150 engine as a donor. Now I decided to use the brake shoes I had as when a 150 which worked great. now I'm guessing the brake cam hole is not quite right so one part of the shoes touches the hub first causing it to rub. Whats the best way to find which part of the shoe touches the hub so I can sand it to fit..All help appreciated... :frog:
ferritt
chalk
LI150
Thanks.. :D
