carb rubber
kipper
Main scooter: li150
ok ive fitted a ribbed malossi rubber,clicked on the carb side spot on and secure even without the jubillee, manifold side needed the jubillee tightened i noticed no internal gap due to built in step on rubber. start up idle good,give it the revs carburetta dysfunctional errection.....(mark dont mention gt kits). glue duly applied retightened seems solid. tried it round the block and its still on, also performance seems much better on low throttle opening....(could this be due to the step in rubber mentioned earlier). come on you racers whats your view? wondering if my imola manifold is not quite round now.
ArmandTanzarian
Does anyone do a stepped rubber from a TM24 to a 30mm monza manifold. I've never been completely happy with the TMX35 on my Series 2. It makes a cool induction noise and uses a lot of fue but doesn't seem to do a lot else that I couldn't get with a smaller carb.
Dazza
A good wash down with carb cleaner before assembly should wash off any oil residue too ;)
Honeymonster
I'm due to fit a TM 24 to a mates scoot when it's run in a bit and the kit he got has a 30mm internal dia manifold and rubber to suit, poss this one, http://beedspeed.com/product_info.php?c ... ts_id=1518
not been too near it yet to comment on fit etc.
Ian
kipper
Main scooter: li150
well the glue lasted about 5 miles with the ribbed malossi rubber and so on with a cut down top hose and narrow clips.....so far so good.
