ts1 + phbh30 jets help
alle
Hi, I've a ts1 with taffspeed and phbh30, anyone knowing a decent setting to start working?
cheers
alle
Diablo
Start rich with:
pilot 50
atomisor AV268
Needle X2(probably top clip)
Main Jet 130+ maybe startsafe at 140
slide 40
You may also need to weaken if needs be with:
AV266 and X7 needle and main jets in increments down to 128.
These carbs work well with bellmouths on TS1s so maybe get one of those as well( the plastic ones are cheap)
A powerjet isn't absolutely neccesary but carburation is improved with one of the camlam ones fitted.
alle
thanks Diablo, good start!!!
OLDSKOOL LAMBRETTA
Main scooter: gp 225 ts1
hi diablo, is the 50 pilot jet richer then a 55 pilot jet, cheers
Diablo wrote:Start rich with:
pilot 50
atomisor AV268
slide 40
Diablo
No weaker
OLDSKOOL LAMBRETTA
thanks for the help diablo, cheers martin.
Diablo wrote:No weaker
    Users browsing this forum: Google [Bot] and 9 guests
