Here's a new MBD speedo in Mouses new headset.
ArKaTxU
Lazarus wrote:
ArKaTxU wrote:This guy have a good fitting guide with good pictures:
http://www.addo-pix.com/ts1-service.html (in the middle of the page)
working
the link is no longer :(
Try this one:
http://www.addo-pix.com/lambretta-ts1-service.html
Lazarus
Thanks very much ArKaTxU just what I was after m8
working
Try this one:
PRE0ATS
Main scooter: Li Silver Special
minotaur wrote: i would like a white/ cream light , like the original set up if this would still work in daylight, i think this would work with most colours, imagine a green light on a red or purple headset? keep it subtle and minimalist this makes it more universal.
In view of the comment above, can anyone confirm if the speedo is still only available with a green backlight?
Whilst the reliability/function of the speedo is the most important thing, I have to admit that I agree with minotaur that a white LCD display would be much more universal - the green light is the one thing making me consider the SIP speedo instead, as the green would look odd with the colour scheme of the project I'm planning.
Ian Hepworth
Green backlight only at the moment. No plans to change that.
madmaex08
the battery in my speedo died. most likely because of the constant freezing cold this winter and the general lack of use of the speedo. do i need to change the battery (and if how?) or is it going to be revived upon firing up the scoot? i take it i need to set it up from scratch though?!
Ian Hepworth
madmaex08 wrote:the battery in my speedo died. most likely because of the constant freezing cold this winter and the general lack of use of the speedo. do i need to change the battery (and if how?) or is it going to be revived upon firing up the scoot? i take it i need to set it up from scratch though?!
The battery will recharge when you start running the scooter again. I'm not sure if you will have lost your settings.
madmaex08
thanks for the quick info; will let you know about the settings.
ulyssescale
working
Try this one:
That link is viable, but the walk-thru for the speedo install is no longer there.
A chicken ain't nothing but a bird.
Train Driver
Did these get sorted in the end or was it another good idea let down by poor suppliers :(
paulmgreen
I have had two that both worked fine......
www.JPPLambretta.co.uk
