Tune a Mugello 186?
Bilko
Main scooter: LI150
Been thinking about my old Mugello 186 V2. It's been run/thrashed for a few years and while the LI is in bits and all over the place. I'm going to strip the engine for a service.
While it's apart, is there anything that could be done to the top end to give it a bit more low down grunt?
Is it worth it?
Bilko's Oily Blog
Bilko
Main scooter: LI150
What did I say wrong? :oops:
Is a Muggy 186 not worthy? :(
Bilko's Oily Blog
What are you running it with carb/exhaust wise?
Chris CSPE
Bilko wrote:What did I say wrong? :oops:
yes it is worth it, wot port timeings does it run, wot carb and exhaust, is it a standard size crank, there is alot you can do but that depends on wot you've already got. There are some good gains to have for a small amount of work.
Bilko
Main scooter: LI150
Thanks. A 28mm Dellorto and a JL1.
Was going to use a 58mm GP MEC Crank
Bilko's Oily Blog
if its low down grunt changes that your after ,then a crank change wont make any difference to performance,,
however..you could try widening the exhaust port to the max width ..and a pipe change such as the ADS 1 with gearing to suit ..
Chris CSPE
Give Al a call at Diablo or pm him and he'll be able to offer you some options that have had good results
Bilko
Main scooter: LI150
Thanks lads, appreciate that.
I'll definately give Al a call. Should have done in the first place.
Bilko's Oily Blog
    Users browsing this forum: Baidu [Spider], Semrush [Bot] and 8 guests
