Kickstart Shaft Piston
Bilko
Main scooter: LI150
I've got nothing to compare, so could someone tell me if this piston is sticking out too far? To me it looks like it's sticking out too much, but the kickstart shaft is new as far as I can tell.
Bilko's Oily Blog
dapper
Rob, I think you'll find that it's the ramp that controls how far out the piston sticks. You do have the Kick Start Piston Circlip on, don't you?
Bilko
Main scooter: LI150
Circlip is in. I've no ramp on my casing
Bilko's Oily Blog
dapper
But if you have a GP ramp built into the GP endplate, you'll have to turn the kickstart shaft a bit to line up the reference pin with the ramp?? That should hold the piston in a bit ;)
Bilko
Main scooter: LI150
Suppose it's the only option left. Cheers.
Where did I see the article on prep and fixing on?
Who does the ramps?
Bilko's Oily Blog
Bilko
Main scooter: LI150
Doesn't matter. I'll have to get another kickstart shaft
Bilko's Oily Blog
DaveTomo
Main scooter: SX 200
I don't know if this helps,I did one on the LCGB site about 8-9 months ago and I think it was also done recently in classic scootering.This is the way I did mine so that I kept the GP endplate which was matched to the engine casing.Take the endplate off and using a dremmel trim the ramp off so that it looks like an LI,SX etc endplate before Image
after Image
compare Image
drill and tap the blanks on the sidecasing assuming its a GP sidecasing and fit a ramp,I think you can them most places got mine from SR ,(think they're out of stock at the moment) http://www.scooterrestorations.com/lamb ... and-bolts/
ramp fitted Image
endplate fitted
All works,takes the strain of the kickstart off the endplate and you can adjust the kickstart "biting" point better plus you've got the stronger GP kickstart shaft.Hope this helps.Dave
fairspares
ive done what davetomo shows here and it works fine.
    Users browsing this forum: Ahrefs [Bot] and 1 guest
