Disc brake house routing?
Robi D
I've got a disc brake kit for my ser. 1 and wold like to know what some people have done to route the hose without going through the headset or horncasting, I don't want to cut them up or drill them. I have seen some pics in the "show us your scoots" section via show your ser. 1, but the pics aren't quite good enough to determine what they have done.
Thanks
some people drill the m/c mount to route through were the cable would have gone under the original lever/switch mount though this requires a hose with removable banjos
just remembered ..........
a few i have seen simply rought the hose through the right hand clamp bolt hole in the head set bottom
Robi D
OK thought I had seen a few that went through that hole, that seems like it might be quite tight. I'll have to check and see what kind of clearance I have there.
thanks
as i said ..if the hose banjo is fixed and cannot be removed it will limmit your options
