wobble in front hub !
scootcoot
Ive just noticed that there's a slight wobble on my front hub (s3 without grease nipples) ! took it off stripped it down all looks OK ,put it back together and drew a pen line around the back plate , spun the hub and it still has a slight wobble of about 1-2mm !!!! :? you see it even more when the wheels back on ,very confusing ! anyone got any ideas what could be the problem ?
am a doogal r u a doogal too....!
jason frost
I take it that there is no play in the bearings ;) then I would check the spindle
psychedelicropcircle
scootcoot wrote:Ive just noticed that there's a slight wobble on my front hub (s3 without grease nipples) ! took it off stripped it down all looks OK ,put it back together and drew a pen line around the back plate , spun the hub and it still has a slight wobble of about 1-2mm !!!! :? you see it even more when the wheels back on ,very confusing ! anyone got any ideas what could be the problem ?
is it a disk brake?
scootcoot
is it a disk brake?
No, its standard drum brake ! what i have noticed is when i put the hub and back plate together ready to tighten up the spindle nuts there is quite a bit of play when rocked side to side !!
    Users browsing this forum: Baidu [Spider], Google [Bot] and 8 guests
