Which 5/6 plate clutch?
jimmo
Main scooter: Lambretta GP TS1 230 JB
Time to upgrade my clutch in the ts1 - which 5/6 plate clutch should I be looking at?
:wtf: :wtf: :wtf:
my taffy tuned ts1 uses a chiselspeed 6 plate with packer and its great but needs a packer making for pipe(pm) and floorboard strut reshaping to allow rear runner to sit a further 10mm away from engine.
my imola & rapido both run a reedspeed six plate which is great needing no mods
my dac is running a reedspeed 6 plate which slips quite badly but that is at 39bhp/26torque (approx) so im fitting one of rocho68's clutches which are cheaper than all other competition and capable (in theory ) of handling upto 50bhp.http://scooterotica.org/forum/viewtopic.php?f=7&t=14329
cvjosh
Main scooter: 150special
mark wrote:my taffy tuned ts1 uses a chiselspeed 6 plate with packer and its great but needs a packer making for pipe(pm) and floorboard strut reshaping to allow rear runner to sit a further 10mm away from engine.
I look forward to your feed back about Rocho68's clutch from what i can see the quality and price looks great. Test it all ready :twisted:
I've fitted surflex 5 plate kits from Andy Francis into a few bikes, including my own revvy mugello and a TS1. Seem to work fine. And, with thinner steels, will fit comfortably in a standard basket.
Ive got a couple of JB Tunings 5 Plates in mine nice clutch and easy on the hand :D
red
I've got a Readspeed 6 plate in my TS1 it was also in all 3 of my RB225's never had any problems with it and it's approx 3 years old.
No packer plate or extended kickstart shaft required
http://www.ekmpowershop2.com/ekmps/shop ... 1193-p.asp
£290
tha83
Main scooter: SX 2something
If you aren't a racerboy a 5 plate clutch can and does work fine. I have machined my crown wheels to suit in 2 different setups and installed the AF 5 plate package and it seems just fine. The spring are a little more mellow than the Barnetts which makes stop and go riding a little easier. Truthfully, the 4 plate with Barnetts held up pretty well for 5,000 miles. I can understand high HP bikes needing a 6 plate but it does all seem like a race to spend stupid amounts of money sometimes.
ArmandTanzarian
It depends a lot on your gearbox. A GP gearbox puts much less strain on the clutch than an SX gearbox.
