rear shocker
psychedelicropcircle
I have an escort shocker on a s1 with a 28mm dellorto (imola) that bounces off the rear runner. Is there a shock that can gain me more height therefore stopping the bottom of the carb meeting the runner???? :wtf:
psychedelicropcircle wrote:I have an escort shocker on a s1 with a 28mm dellorto (imola) that bounces off the rear runner. Is there a shock that can gain me more height therefore stopping the bottom of the carb meeting the runner???? :wtf:
Take the shock off and measure the distance between it's centers, serties 1 and 2 should be 310mm, series 3 are 300mm. That will tell you if you have the right shock but I THINK the S1/2 ones are the longest available.
What are your engine mounts like? if they are worn I think that would have the effect of lowering the engine relative to the frame, not by much though :?
djh66
Main scooter: 150 special
A series 3 shock is shorter than a series 1/2, and will give you more clearance from carb inlet manifold to frame, especially on a big carb. It may be someone has put a series 3 shock on, for that reason.
A series 1/2 shock will lift the scoot up to correct height, but then may foul the carb/frame :roll:
Bring Me Sunshine COYH
djh66 wrote:A series 3 shock is shorter than a series 1/2, and will give you more clearance from carb inlet manifold to frame, especially on a big carb. It may be someone has put a series 3 shock on, for that reason.
He's talking about the carb hitting the runner on an Imola with carb on the other side not the frame which is the usual problem.....at least that's what I thought he meant :?
djh66
DOH! But if he's got a series 3 shock on, maybe the cause
    Users browsing this forum: Google [Bot], Semrush [Bot] and 9 guests
