Gianelli question
sydduckett
Helping a mate build hois scooter and he has got a 2nd hand Gianelli snail for a imola but hasnt got a stub for it. Its the same one as in stickies book. Question i have is, does the stub need to be a gianelli one or will other sorts fit and if so which ones?
Have been looking online and cant seem to find Gianelli stubs.... :?
Any help greatly appreciated
sef
Agent Buchwald
Sef, I've got one to use as well, should be a laugh, the stub won't work with the JL/Taffspeed type of stub and must be totally different - I'm going to cut the exhaust and weld on the same diameter tube so that it will use the JL stub - easily available and can swap out to a JL.
Otherwise CamLam have a bit of knowlege and might have a spare stub - let me know how you go on with it.
sydduckett
Agent Buchwald wrote:Sef, I've got one to use as well, should be a laugh, the stub won't work with the JL/Taffspeed type of stub and must be totally different - I'm going to cut the exhaust and weld on the same diameter tube so that it will use the JL stub - easily available and can swap out to a JL.
I can see this becoming a nightmare... :( Got this pipe for a mate to help finish his scoot as hes new to scooters and is fast running out of money..Thought i was getting a result only paying £30 for it (needs a bracket welding) may turn out to be atd more exspensive than i thought... :D
Agent Buchwald
Not necessarily, if you've got a bit of welding to be done anyway then welding the flange on will hardly cost and ebay or a wanted on here should throw up a JL manifold for a tenner, it's never easy is it?
Agent Buchwald wrote:... a JL manifold for a tenner...
think I might have one, can take a look if you like? or is it a NK type stub that is like just the inner bit of a JL one...? so the expansion pipe just sits on the outside, rather than being sleeved by the stub...? got one of them too if you want me to measure that.
sydduckett
cheers Byron, I dropped it round Johns yesterday so will pop round and measure it up and come back to you.
Thanks for the offer
sef
