Replacing shock rubber bushes
byron wrote: can the metal sleeve be removed from the rubber ? and then refitted once the rubber is in ...?
No, it's bonded in. You'd probably wreck the whole bush attempting to remove it.
Dazza
All sorted now thanks to different bushes from Martin (Corrado) :D
Cheers matey..
