54mm stroke crank
does anyone do a 54mm stoke crank? thanks
rakki
Main scooter: sx|px|rally×2
AF Rayspeed has them on their website.
Ian Hepworth
Omega (went on to be Mec-eur) made some in the 80s. I got a used GP one recently to use with my autisa kit.
rocho68
What u planning now kidda!
ktm sx125 looks similar size spigot to small block casing and kicks out 33bhp and 36bhp when turned to 144 big bore . already know dtr 125 ignition will fit gp boss.
Ian Hepworth
mark wrote:ktm sx125 looks similar size spigot to small block casing and kicks out 33bhp and 36bhp when turned to 144 big bore . already know dtr 125 ignition will fit gp boss.
run it 58mm and take advantage of the extra cc's? or are you trying to do a bonkers 125?
legalish 125 i think, mind you 58mm and packers might work
rakki
Would it be possible to utilize eccentric crank pin facing inwards? Assuming that this setup needs "exotic" con rod and therefore custom made crankshaft.
bsso78
Ive got a 54mm stroke crank from my old Group 3 150,it was getting tired so had a new bearing and rod fitted but never used after that if anyone wants one
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
