Piston shims???
LI150
Main scooter: Series 2 LI150
Im just building a 200 engine and Im fitting a standard top end using a 3 ring piston. The crank Im using is a mec. Do I have to use shims and if so can I use the wider bearing?
All help appreciated :lol: :lol: :lol:
if your crank has shims you dont need piston shims, always fit the widest small end bearing you can
LI150
Cheers Mark... 8-)
    Users browsing this forum: Ahrefs [Bot] and 9 guests
