Fork Buffer Retaining Clips
jackojacks
Hi all im just letting you all know i make Fork Buffer Retaining Clips. for when yours have rusted away. or if you want to get rid of those ugly bolt in rubber buffers [ which is what i mainly use them for] just carefully position these and plug weld them in thru the bolt holes linish off and you cant tell there were any bolt holes. i have already supplied a set to a member on here and a set to his mate.
they are available on ebay but if any members on here want a set of four if you pm me thru here you can have them for £10.00 pound inc del [ saving you £1.99 p+p ]
They are hand forged and kept to a tight tolerance made by a scooterist for fellow scooterists.
Hope this doesent break any forum rules just trying to help fellow scooterists out ;)
Do you have any pics of said clips and of a finished jobbie?
jackojacks
The clips are pictured on ebay. leave it with me i have got a set of chopper forks with some welded in in the garage i will take a pic tomorrow and load it up.
soosh
Ive used these clips recently and the buffers went in perfectly.
Good service from Jacko.
