breather plug
Tosh
just wondering, all my engines have had breather plugs fitted to the top of the engine but noticed my broth`s only got a blank plug fitted like the drain plug, he`s been everywhere on is scoot and not one bit of trouble,so should we or shouldn`t we ,wots its purpose ?
well i know the thread is the same but there should not really be a problem as far as i can see unless a seal goes
Tosh
RICSPEED wrote:well i know the thread is the same but there should not really be a problem as far as i can see unless a seal goes
thanks for that ,but is it their so the oil can breathe as to not create pressure in side the engine
i,ve always supposed that a breather is needed..............even though your bros is ok so far.............i would use one just to be on the safe side..............
if a breather was not needed............then why did all previous models have them...........?
i have seen a few indian motors supplied blanked off as you say..........but dont think thats a good thing.................... :lol:
i would say it would be better with the breatheher
J1MS
sean brady scooters wrote:i,ve always supposed that a breather is needed..............even though your bros is ok so far.............i would use one just to be on the safe side..............
Totally agree...If any pressure builds up in the casing, the oil in the case can only be pressurised, I can confirm this as Ihad a back wheel oil seal blow when I put a blank in my GP instead of a breather... :o
Tosh
thanks again for the replys i`ll try to bend is arm to put one on :lol:
RBG
Increase in temperature = increase in pressure, only way out is through a seal.
    Users browsing this forum: Semrush [Bot] and 15 guests
