End can suggestions
sydduckett
The end can on my franspeed rocks in the sleeve, resulting in the exhaust blowing even whgen stuufeed with exhaust sealer....any suggestions?
ta
sef
monkey boy
Hi what about one of these???
http://www.lambrettaspares.com/sparepar ... u0445.html
Never tried one but it might be OK.
CHEERS AL
idealy the sleve should be slightly conical to ensure a good seal with the retaining springs
sydduckett
RICSPEED wrote:idealy the sleve should be slightly conical to ensure a good seal with the retaining springs
conical in what way?
ta
sydduckett
monkey boy wrote:Hi what about one of these???
CHEERS AL
Does this fit/slide over the slip joint? If so could well be worth looking into. Anyone used this before?
ta
ta
i just meant a lot of high end systems have joints in the pipe that taper slightly so that under tention of the exhaust springs will pull tight ,i not suggesting that yours is like this but this is an example of why it is done ,to stop gaps at the joints ;)
chris2470
Ive heard that a small section piece of cycle inner tube can cover this area and do the job, or cut the finger off a neoprene glove.
Best Regards
Chris
blue
As already suggested mountain bike inner tube cut into a section about 40mm long.
Been using it for a few years now with no problems, every 2-3000 miles replace it with a new piece.
Stian
[quote="blue"]As already suggested mountain bike inner tube cut into a section about 40mm long.
Does't the rubber just melt?
blue
No, not on the rear slip joint.
