TV175 Series 3 -62, restoration
kejj wrote:It's an expensive country.
So, you think I can devcon or Helicoil it myself in spite of the crack?
In Sweden an electrician takes round 60 to 100 £ just to look at your problem.
I wouldn't know were to send it!
you arrange shipping ..i could sort it
kejj
Good idea Ricspeed but a couple of question arise there.
1. shipping cost
2. who are you and what welding referenses do you have?
just for a start :)
________________________
http://tv175.wordpress.com/
kejj
Some details, Click image for larger version.
kejj wrote:Good idea Ricspeed but a couple of question arise there.
1. shipping cost
just for a start :)
shiping cost is up to you to get a quote
im called rich and i live in york and i know a good engineer who could sort that no proplem
its up to you .....i would only want payment for work done im not asking for myself
kejj
Thanks Ricspeed, will consider it.
I got a LI150 S3 block of for £25 yesterday, will inspect that one and see if it's usable, it's been sandblasted with the crank and front sprocket in.
psychedelicropcircle
any joy with your engine case? ive got a tv2 case in just now will post some fotis up when it returns, it would be a shame to not keep the original case with the scoot. :arrow:
kejj
psychedelicropcircle wrote:any joy with your engine case? ive got a tv2 case in just now will post some fotis up when it returns, it would be a shame to not keep the original case with the scoot. :arrow:
exact my thought. I prefere a tv casing. mines fine except for one crack, to bad the weldning and drilling cost so much here.
joespeed
i think your best bet would be to take ric up on his offer,surely the postage cant be that expensive,or is it the thought of ric not sending your case back!
regards
joe
kejj
joespeed wrote:i think your best bet would be to take ric up on his offer,surely the postage cant be that expensive,or is it the thought of ric not sending your case back!
regards
joe
He is so active around here that I think he is credible on sending it back.
Shipping from sweden to UK is 40£ so it ads up quickly.
The LI case was even in a worse condition than mine. Got another one though for 60£ so right now, if I wont find a good local aluminium welder that knows about welding engines I will restore my TV engine in the Li S2 case. From what I figure it should be a direct swap.
Btw, the large block / small block references, do they refer only to the cylinder head?
joespeed
the li and tv cases are both compatible with parts,but if you are an 'anorack' i think you would be better suited to let ric get your case welded and back to original , ric is very active and i think he will return your engine without any problems!
small block is refering to 125/150/175 cylinder stud spacings,big block is 200cc cylinder stud spacings,
regards
joe
    Users browsing this forum: No registered users and 32 guests
