Page 1 of 2
Series 1/2 front mudguard fitment
Posted: Mon Mar 28, 2011 8:53 pm
by MAB
Hi,
After a bit of advice and a photo if there is a chance.Which are the holes that you mount your mudguards LOWER tubuler mounts to,a friend of mines legshields have a couple of mounts already tacked to the legshiels but mine believed to be early series 2 do not so unsure where to fix to do i need to drill 2 fresh holes ? - any ideas would be appreciated .
Regards Mark
Re: Series 1/2 front mudguard fitment
Posted: Mon Mar 28, 2011 8:57 pm
by RICSPEED
dont drill .....ill get a pic up
Posted: Mon Mar 28, 2011 9:02 pm
by RICSPEED
its the raised bit below the three hols for the runner strips at either side
Posted: Mon Mar 28, 2011 9:05 pm
by MAB
Bit of a problem my legshields dont have those 2 raised areas, have you seen any that dont before ?
Mark
Posted: Mon Mar 28, 2011 9:08 pm
by RICSPEED
MAB wrote:Bit of a problem my legshields dont have those 2 raised areas, have you seen any that dont before ?
Mark
yes ...............spanish ones
Posted: Mon Mar 28, 2011 9:13 pm
by MAB
Mmmmm these must be spanish then , any ideas where these bolt through sorry for so many questions set my self a bit of a deadline to get it ready for scarborough
Mark
Posted: Mon Mar 28, 2011 9:18 pm
by RICSPEED
bolts dont go through the leggies as these are just captive nuts efectively welded on to fix mudgard to
Posted: Mon Mar 28, 2011 9:23 pm
by MAB
Legshields are now painted and with none of those captive nut/brackets not really sure where to fix to, head scratching time again i think.
Mark
Posted: Mon Mar 28, 2011 9:26 pm
by RICSPEED
well unless you want a bolt head between the runners inside the leggies ....you need to weld some on mate
Posted: Mon Mar 28, 2011 9:28 pm
by RICSPEED
what happend to the dry build????
