Page 2 of 3
Re: chrome frame ring removal
Posted: Fri Oct 21, 2016 10:35 am
by HxPaul
YAMLAM wrote:i had to replace one for a mate recently. i bought a 1mtre length of 16mm studding, ran a nut down about 35mm then put a rear hub cone on with the larger taper facing up, after heating the fork tube a bit i inserted the studding from the bottom end of the tube and used a club hammer to bash the old ring out, i had to re heat the tube four times before the bugger came out.
+1 The only thing to add is-dont forget to remove the grub screw holding the chrome ring in the frame.................you'll be surprised how many people forget.
Posted: Fri Oct 21, 2016 11:29 am
by YAMLAM
very true, although the rings are such a tight fit ,i cant see what the grub screw actualy does.
Posted: Fri Oct 21, 2016 12:10 pm
by HxPaul
I think its mainly to stop the chrome ring from turning when the steering lock is applied.
Posted: Fri Oct 21, 2016 7:17 pm
by hendy
Scooterdude wrote:I'm sure I heard somewhere that the eBay stainless ones are made wrong thus not making it possible to use the steering lock.
Aye, it was me who said that but I was talking out of my arse.
I'm reasonably good at the lambretta thing but having got back into them after more than 20 years I do talk s**t every now and then. Unintentionally of course.
Posted: Fri Oct 21, 2016 8:00 pm
by Scooterdude
hendy wrote:Scooterdude wrote:I'm sure I heard somewhere that the eBay stainless ones are made wrong thus not making it possible to use the steering lock.
think we're all guilty of that from time to time boss. After all it is the Internet !
Posted: Thu Jan 05, 2017 10:00 am
by mr mugello
Got my old one off. Not priced up the cost to get my original re chromed but I'm thinking its not going to be cheap. Was going to replace with Scootopia copy, not sure now ? Bit of a pain these items .
Posted: Thu Jan 05, 2017 10:07 am
by mr mugello
Scooterdude wrote:I had to thrash mine out from the bottom with a long steel bar and a very big hammer. But be carefull what you replace it with! I started by trying to fit a scootopia one that apart from being the wrong shape cut a groove in the back of the headlight. I then spent forty something quid on a Casa one in the belief that as it was Casa and expensive it would fit, well it ain't great I can tell you and about six months down the road I've noticed the Chrome plating is beginning to flake off! With hindsight I would have been better off replating the original one.
Did Scootopia send you a series 1 type part by mistake, when you say it was the wrong shape. Or are Series 1 a total different tube frame size.
Posted: Thu Jan 05, 2017 3:23 pm
by Scooterdude
mr mugello wrote:Scooterdude wrote:I had to thrash mine out from the bottom with a long steel bar and a very big hammer. But be carefull what you replace it with! I started by trying to fit a scootopia one that apart from being the wrong shape cut a groove in the back of the headlight. I then spent forty something quid on a Casa one in the belief that as it was Casa and expensive it would fit, well it ain't great I can tell you and about six months down the road I've noticed the Chrome plating is beginning to flake off! With hindsight I would have been better off replating the original one.
I'm really not sure what they sent but when I placed the old one over the Scootopia one there was quite a difference in shape/diameter, that's after I took it off as it was cutting a groove in the back of the head lamp.
With hindsight I'd definitely have had the old one re-chromed.
Posted: Tue Jan 10, 2017 12:50 pm
by HxPaul
Scootopia are advertising Lambretta chrome rings on ebay,their are three photos,one for a series 1,one for a series 2 and one for a series 3.The photos for the series 1 and the series 3 use the same photo for each one,the one for the series 2 is completely different.The series 3 chrome ring is completely different from the series 1.Maybe they've sent you the series 1 by mistake.
Posted: Tue Jan 10, 2017 3:47 pm
by Scooterdude
HxPaul wrote:Scootopia are advertising Lambretta chrome rings on ebay,their are three photos,one for a series 1,one for a series 2 and one for a series 3.The photos for the series 1 and the series 3 use the same photo for each one,the one for the series 2 is completely different.The series 3 chrome ring is completely different from the series 1.Maybe they've sent you the series 1 by mistake.
Just checked the invoice and it states series 3, but it could have been a simple order picking mix up so best thing to do is always check against your original part whenever possible.
