Newly rebuilt engine, zero miles. new MB hub bearing and new SKF end plate bearing. Gearbox shimming close to the minimum gap.. Can't remember exact figure.
When on the centre stand I can move the rear wheel slightly and hear a knock which I guess is shaft in the end plate.
Hub correctly torqued.. Guessing its not normal and side case has to come off??
S3 layshaft slop
- registered user
- Contact:
- garry inglis
- registered user
- Main scooter: ts1 230 and rb200
- Contact:
I've found most problems with wheel wobble is endplate bush but I've had mb bearings that fail
- registered user
- Main scooter: Lambretta LI 125 S3
- Contact:
Easy to diagnose, with the side case off place a wide bladed screwdriver between 1st gear and the casing give it a wiggle and see if there is any movement.
Ive done a couple recently and have replaced with the excellent Scootopia bearing and track.
- registered user
- Contact:
Will start taking the side case off and see what's going on inside. Strangely there is more movement when on the stand compared to rear wheel off the ground.
- registered user
- Contact:
So side case off and there is some movement of the shaft at the end plate needle cage.. That's a bit s**t as I had replaced the needle roller and the holder during the rebuild.. It could also be the shaft.
- garry inglis
- registered user
- Contact:
if you still have the old endplate race measure the inside dimension and check the new one as theres nothing to say the new one is made to the exact tolerence needed
- registered user
- Contact:
As Gary has suggexyed/suspected, the new bush/bearing cage is a big bigger compared to an original unit.
Would anyone have an MB layshaft and a good set of digital verniers or a micrometer and can measure the end of the layshaft for me so I can compare to mine before I lay out £150 for a new one.
- garry inglis
- registered user
- Contact:
I would put your old bush back in and put the endplate back on and try that
- registered user
- Contact:
New replacement bush is too big.. Typical
- garry inglis
- registered user
- Contact:
Well I've measured my bits as you can see the new scootopia bush is spot on a nice fit to layshaft with a bearing in the Spanish one was a right fit but good the first Italian at 23.43 was slack so would definitely wobble but a good example of how little ware can cause a problem
