Wont idle!
Posted: Wed Apr 26, 2017 2:14 pm
by Suede Ed
Casa 185 fitted with a 25mm phbl (straight out of the box) through a drilled airbox. Pipe is AF clubman. Starts fine, runs ok, but will only tick over fast with a little pressure on the throttle. Idle screw seems to have no effect??
Re: Wont idle!
Posted: Wed Apr 26, 2017 3:50 pm
by holty
have you checked that the choke is in the off position, and the plunger is all the way down with a little bit of free play on the cable ?
Re: Wont idle!
Posted: Wed Apr 26, 2017 4:10 pm
by camel
Sometimes the spring becomes coilbound on dellorto,s preventing you winding it in enough to raise the slide,worth a look,if so just shorten the spring a tad
Re: Wont idle!
Posted: Wed Apr 26, 2017 4:15 pm
by camel
On the tickover screw i should add
