rustproofing a pegasus seat base
- registered user
- Contact:
was quite horrified to see how rusty my seat base was when i took the cover off, it had previously been blasted and stoved, can anyone suggest the maximum protection i can give it for the maximum length of time
- registered user
- Main scooter: lambretta ld auto
- Contact:
Hi.I would get it acid dipped then zinc plated..etch primer then black two pack paint with a mist of clear wax oil to protect it once painted.
regards
Dean
regards
Dean
I thought of having my seat base blasted / zinc plated and powder coated but then cleaned the seat base properly an just covered with Owatrol/Waxyoil. Came out quite good.
Worth a try before spending cash.
- registered user
- Contact:
One chip with powder coat the water gets under it as there's no etch onto the metal like spray etch painting
- registered user
- Contact:
Water will get under powder coat quicker than under spray etch primer,this suggests that two pack is a better method.
Dean
Dean
