variatronic
joespeed
i need a wiring diagram for the variatronic system,
regards
joe
Bilko
Main scooter: LI150
Does this help
Bilko's Oily Blog
Bilko
Main scooter: LI150
DOH! Didn't see your post Mark.
Bilko's Oily Blog
Diablo
Stickys new book has got a good one
joespeed
thanks for all your replies,mark that is just what i need .
regards
joe
joespeed
i thought the variatronic was a good idea,mine has just spun the flywheel rivets off mangling every thing all the stator is scrap ,
back to the indian gear (at least it is cheap to replace)
has any one out there got any bits to fix this variotronic kit up?
regards
joe
mickyb
the best way to sort the flywheel is to punch out the 5mm rivets, you can then tap the holes in the boss to 6mm, countersink the inside of the flywheel holes and use countersunk screws and loctite to hold it all together. There are two larger rivets that can be used just loctite them in place. I,ve had to do this twice now but had no problems since. First time ripped all the wires on the stator but managed to rejoin them, sencond time didn't give it a chance.
joespeed
the flywheel will go again but i will need to know the exact position of the key way to the pick up where ever it is,there must be a 'right' position.
regards
joe
GP Kevo
I thought these Varitronics were better quality. Seems like the best is still the original Ducati made AF Electronic.
    Users browsing this forum: Amazon [Bot] and 8 guests
