Page 17 of 22
Re: 12V DC CONVERSION - HOW TO
Posted: Sun Aug 19, 2012 6:44 pm
by coaster
rosscla wrote:^^
That's pretty much where I am and the conclusion I came to in looking for a switched live in position 1.
Everything in the headset is live all the time but controlled by the switch. The only thing that worries me is the brake light switches. All it takes is some funny fecker with a brick or a rubber band and your battery is flattened.
I was wondering if it might be worth including a battery isolator of some description?
Fit an LED rear light and it won't matter, the drain in that unlikely event would be minimal.
Posted: Mon Aug 20, 2012 10:23 am
by rosscla
Yes, went down that route too :bigsm:
Posted: Mon Aug 20, 2012 12:08 pm
by ArmandTanzarian
I found that my battery kept going flat after a few days without using the scoot. I fitted a battery isolator switch which seems to have done the trick. I'm not sure where the current was flowing. The only thing I could think of was that it was somehow leaking through the stator windings but that's just a wild guess based on very little knowledge.
I recall that the 80s AF Ignitions did the same thing if you used them in DC mode.
Posted: Sun Aug 26, 2012 11:31 am
by purple_pill67
Got one too, alswell as a H4 conversion and led speedo bulb (found a pair of 2inc post on ebay for about £1.70-think they are the same as some car interior lights)
Posted: Sun Aug 26, 2012 12:38 pm
by rosscla
I think there must be some leakage somewhere along the line as I seem to get a reading of 0.3 - 0.5 VDC on some of the wires and earth even when the switches are off.
I've fitted a battery isolator switch now too.
Posted: Thu Sep 20, 2012 12:59 pm
by vRSG60
Ive had this conversion done for a couple of months now so I decided to use my Pathfinders (Phillips Vision bulbs) when riding during the day instead of my headlight. The battery powers them for about ¾ of an hour before they look like candles
So not enough charge put into the battery to recoup the power needed to run the lights. LED re-installed now, I'll see how these go on.
Posted: Thu Sep 20, 2012 3:30 pm
by coaster
vRSG60 wrote:Ive had this conversion done for a couple of months now so I decided to use my Pathfinders (Phillips Vision bulbs) when riding during the day instead of my headlight. The battery powers them for about ¾ of an hour before they look like candles
That's only to be expected, the combined current draw from those Pathfinders will be more than a Lambretta stator can produce. If spots are wired to only be swoiched while high beam is on then and then only when really needed, the battery should hold up for hours provided it is big enough (7 amp/hour.
Posted: Thu Sep 20, 2012 3:54 pm
by vRSG60
[quote="coaster
That's only to be expected, the combined current draw from those Pathfinders will be more than a Lambretta stator can produce. If spots are wired to only be swoiched while high beam is on then and then only when really needed, the battery should hold up for hours provided it is big enough (7 amp/hour.[/quote]
Yeah, it's as I thought.
I have my lights switched via the key switch.
0 = ignition off
1 = ignition on, lights off
2 = ignition on, headlight or side lights on
3 = ignition on, Pathfinders on & headlight or side lights on
I've been running position 3 with Pathfinders & sidelights.
LED technology is coming along nicely. Soon they may even project some light onto the road
Posted: Thu Apr 03, 2014 2:51 pm
by dapper
If I've already converted to DC, do I just need to connect a cigar lighter socket to the DC output from the Wassell reg to be able to charge mobile phone etc.??
Posted: Thu Apr 03, 2014 6:24 pm
by soulsurfer
You could, but I'd recommend taking it from a battery being charged from the red output of the Wassell, otherwise you could blow the device, as this isn't a stable voltage.
