Progressive fork springs
- scooterslag
Yes I had the MB spring set up in my forks and just found them way too hard, they used to bounce over road imperfections and I didn't find them a very pleasant ride. Bit of a bugger to fit as well I fitted the Scootopia spring set-up ( can't remember if its progressive or not) and now its a decent ride. They just give them same level of riding as a good OEM spring set up. Paul
The mack daddy on the left!
- Main scooter: Lambretta series 3
Ok l will give them a try then ,cheers Paulscooterslag wrote: ↑Tue Dec 20, 2022 1:46 pm Yes I had the MB spring set up in my forks and just found them way too hard, they used to bounce over road imperfections and I didn't find them a very pleasant ride. Bit of a bugger to fit as well I fitted the Scootopia spring set-up ( can't remember if its progressive or not) and now its a decent ride. They just give them same level of riding as a good OEM spring set up. Paul
BGM do 10% stiffer fork springs ! Haven’t tried them but would be interested in any feedback on these.
Mrnice71 did you buy the Scootopia springs (standard or progressive) and have you had chance to try them ? As I’m also in the need for new springs.
Standard Lambretta disc but with reverse pull and standard type dampers.
That’s a thought, decision time !
