Chain case leaking
- registered user
- Main scooter: Lambretta 125 special
- Contact:
Hi.i have an oil leak from chain casing.Will it affect the performance of the engine.Its only a small leak.cheers simon
- registered user
- Main scooter: Lambretta L.I. 200 special
- Contact:
I would have thought if oil can get out air can get in
- drunkmunkey6969
- Moderator
- Contact:
Air in the chaincase is not a problem. No oil in the chaincase is a problemLambretta67 wrote:I would have thought if oil can get out air can get in
- drunkmunkey6969
- Moderator
- Contact:
As long as you keep it topped up at all times it will be fine, but it’s probably an easy fix if you have a go.Simon lambretta wrote:Hi.i have an oil leak from chain casing.Will it affect the performance of the engine.Its only a small leak.cheers simon
- registered user
- Main scooter: lambretta li 125
- Contact:
If it's from the gasket face, Darrell Taylor does some lovely thick gaskets that compensate for minor damage and heat distortions really well. They've worked for me a couple of times.
- registered user
- Contact:
Hi all, replaced gasket with a cork one.Reason for the leak 2 studs had come loose. So I heli coiled them in.I hope that’s the corrrect bodge.Cheers Simon
- EddieStone
- registered user
- Main scooter: Lambretta Li 150
- Contact:
Lambretta Upgrades do really nice gaskets in different thicknesses.
