Lambretta Gear Oil
operonalan
Main scooter: tv200
Anybody using ENI Rotrax 80W-90 gear oil
EP rated .... ? Is it applicable for use as lambretta gear oil ?
Muppet
EP = extreme pressure if you use it your clutch will slip
C’est la vie
operonalan
Main scooter: tv200
Think I got that wrong it's Not EP rated the
ENI MP Rotrax 80W -90 is the one that is EP rated ...... One I referenced above ( without MP in reference ) in data sheet states for not excessive pressure conditions .........Got it from Chiselspeed so presume it's ok ... Just that I've never used it before and wondered if anyone had to give some feedback
fluff34567
Check the GL rating, if its 4 or 5 and you have bronze bushes in your engine then forget it.
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 5 guests
