Welcome to the 21st Century
- Doom Patrol
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
Finally I've bit the bullet and swapped my trusty 22mm Dell'orto for a 25mm PHBL. I've always run standard carbs previously. But finally I fitted a kit that needs a bigger carb, and what a difference it makes. It just feels better all round. It remains to be seen if it is any less economical, but to be honest it's probably worth it for the improved quality of the ride.
Well done. Sometimes we have to move on. maybe an expansion box in a few years but one step at a time
- Doom Patrol
Doesn't a standard carb feel stiff afterwards though? I jumped on another scooter and I thought there was something wrong. The smoothness of the throttle on the PHBL just makes riding so much nicer.
- Doom Patrol
I'm running one through a standard airbox. Not drilled at all. Although I do use the BGM filter.
- Muttley McLadd
It's a slippery slope. Next it'll be indicators.. before you know it, a filthy auto will have a place in your garage, and you self respect will be a thing of the pastDoom Patrol wrote: ↑Sat Aug 10, 2019 7:15 pm Finally I've bit the bullet and swapped my trusty 22mm Dell'orto for a 25mm PHBL. I've always run standard carbs previously. But finally I fitted a kit that needs a bigger carb, and what a difference it makes. It just feels better all round. It remains to be seen if it is any less economical, but to be honest it's probably worth it for the improved quality of the ride.
- Main scooter: Lambretta
What's wrong with indicators?
And the Ph range are so last century
