NK Exhaust Sleeve
Spud
I'm looking for one of the sleeves that fit over the join of the end can to the exhaust?
Its for an NK road, anyone know who sells em?
cheers
Spud
PM sent.
nellyboyo
Sleeves ???
I`ve got one and it does blow a bit here , is that the concern ?
10 inch Terror
Xbox live gamer tag: No.
If you mean the rubber sleeve that's supposed to stop oil leaking from the joint, don't bother. They don't fit very well and still leak.
Mine fits and works, go figure.
Trick is getting one that's the right size at each end and is tight to get on.
carlos fandango
Yes they work great :-) ive got readspeed ones on a jl and on an nk , niether leak. Mine are cable tied at each end .
I used some copper wire each end one I fitted for someone
10 inch Terror
I've had two 'perfect fit' ones before. For a Jl and NK pipes, both were complete rubbish. I must be the most unluckiest consumer on planet earth! :(
MAB
Electric Heat sleeve IMOP is a far better looking and tighter seal.
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 14 guests
