filter oil
Posted: Thu May 06, 2010 9:44 am
by johnd
Anyone know if you are supposed to use filter oil with the cam lam easy breathe filters?
Re: filter oil
Posted: Thu May 06, 2010 11:50 am
by GP Kevo
Good question. Every foam filter that I've seen has required foam filter oil to capture small particles that the filter material alone would let past. There again, going from open bellmouth to dry Breathing Sweet must be a major step forward for clean air to your engine.
Re: filter oil
Posted: Thu May 06, 2010 12:55 pm
by Doom Patrol
Are they dry? As I understand it the foam does bugger all except allow air to pass through. As you say Kevo, it's there to hold the oil which is what traps the dust particles. Apparently.
Re: filter oil
Posted: Sat May 08, 2010 11:22 am
by sideout
My foam filter has been soaked in 2 stroke oil since the day I fitted it.
