End Plate Dowel.
Posted: Tue Feb 10, 2009 12:01 am
by RBG
I'm building up an Indian case & wondering if Loctite 243 is up to the job of holding
the end plate dowels in place.
Thanks.
Re: End Plate Dowel.
Posted: Tue Feb 10, 2009 10:28 am
by Daggs
If the dowels are a bit slack in the holes. Use a centre punch to dot them in three or four places, then loctite them in.
Posted: Tue Feb 10, 2009 2:14 pm
by Dell Oughta
Be careful when using the thread lock, put too much in and it may burst through the casing (as it did on one of my endplate bolts :oops: )
Mike
Posted: Tue Feb 10, 2009 3:28 pm
by RBG
Thanks for the replies.
I've just been having a good look at it.
Odd but the dowel can be pushed through the end plate its self, even though its a tight fit.
Or should i say could, I've just had a chisel on it & deformed the hole with a gentle tap.
I'm sure they don't normally push through or maybe someone had done this to the end plates I've come across before.
Anyway its sorted.
Thanks
RBG
Posted: Tue Feb 10, 2009 6:10 pm
by shocky
RBG wrote:Thanks for the replies.
Anyway its sorted.
Thanks
RBG
IVE HAD THAT ALOT ON INDIAN CASES JUST DOT THE HOLE AS HAS BEEN SUGESTED
