Light issue
GlosRob
My Gp was rebuilt last year and was garaged most of the winter before it's nightime maiden voyage last week.
Whilst out I noticed with the high beam on you can just about see on low it's pathetic and the rear is very bright so much so it overpowers the brake light.
It's a full TS1 with electronic ignition etc in a GP frame.
I am shite with electrics so would appreciate some advice.
bristolmod
your rear light issue could simply be the tail light wire and the brake light wire in the wrong sockets.
Scootering since 1968.
firekdp
bristolmod wrote:your rear light issue could simply be the tail light wire and the brake light wire in the wrong sockets.
This would also make the headlight dimmer than it should be.
GlosRob
Do you mean into the regulator or connection to the back light ?
firekdp
The connections at the rear light.
GlosRob
Cheers guys I will switch them over and see what happens
which could simply be the bulb is in the wrong way round...
some of the GP light units aren't too precision made and do allow this...
GlosRob
Well the back light is sorted I think there is an issue with the front bulb but it was the rear that had me scratching me head !
    Users browsing this forum: Ahrefs [Bot] and 3 guests
