MBD Race-Tour piston
Posted: Tue Apr 27, 2010 11:04 pm
by celt
Received today a 'B' grade race-tour piston for my TS1 from MB Developments.
I did request an 'A' grade piston to compliment my 'A' grade barrel, but unfortunately they were out of stock on 'A' grades.
They said that it would be ok to use and that a 'B' grade piston will fit in slightly tighter. I thought it was the other way around and that it would be slightly looser.
I know we are only talking microns but will this piston grade be suitable to use.
I have done less than 1000 miles on the barrel
Re: MBD Race-Tour piston
Posted: Tue Apr 27, 2010 11:08 pm
by sean brady scooters
yes i,m sure thats good to go also.if MB say so.
ideally another grade A would be good,but if you cant get one........... :roll:,what can you do..?
just fit and use the B,and take it gently for a few 100 miles to be on the safe side...
Posted: Tue Apr 27, 2010 11:47 pm
by Ian Hepworth
sean brady scooters wrote:yes i,m sure thats good to go also.if MB say so.
Ideally you match the grades but you can go up or down a grade, it's only microns.
This info was got from AF ages ago.
Posted: Tue Apr 27, 2010 11:54 pm
how many microns is the difference exactly Ian,
i,ve always presumed that the grade b was to take up some slack and wear from an A...etc.
Posted: Wed Apr 28, 2010 11:25 am
by celt
So to re-cap 'A' grade pistons have the slackest fit in microns compared with B, C, and D grades which have a progressively tighter fit.
i.e you can use a 'B' grade in a slightly worn 'A' grade barrel and 'C' grade piston in a worn 'B' grade barrel etc
But not an 'A' grade piston in a 'B' grade barrel as it may be too slack
Is this correct
Posted: Wed Apr 28, 2010 1:04 pm
by Ian Hepworth
celt wrote:So to re-cap 'A' grade pistons have the slackest fit in microns compared with B, C, and D grades which have a progressively tighter fit.
Is this correct
You can go up or down one (i.e A piston B barrel) but no more than that (A piston C barrel).
If in doubt ring the shop, 01709 869756.
Posted: Wed Apr 28, 2010 10:41 pm
by celt
Ok cheers
Posted: Wed Apr 28, 2010 11:30 pm
by Wayne Miller
Hi Celt,
I put a 'B' grade Racetour into my ts1 cylinder after porting and new nicasil, it worked a treat.
As was said above just take it easy first couple of hundred miles and Sean's right if MB says its good to go then its good to go :-)
