PANEL LOCK MEASUREMENT
Posted: Mon Apr 26, 2010 9:02 pm
can any of you fine chaps tell me how far down from the top of the panel you drill the hole to fit a panel lock, thanks
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
thanks for that, intend using cam lock, with 20mm hole, seen the sterling ones, 27mm long. cheersyian-ts1 wrote:Chippy
What sort of lock you planning to use?
Will post my lock position tomorrow if it helps
