fitting LML/Vespa pickup
Posted: Mon Feb 09, 2009 3:45 pm
by Bufficus
If fitting an LML/Vespa type pickup to a SIL stator am I right in thinking you need to remove the top laminate otherwise the pickup catches on the flywheel?
The LML pickup I intend to use seems to be about 1mm thicker than the SIL part.
Re: fitting LML/Vespa pickup
Posted: Mon Feb 09, 2009 9:30 pm
by sean brady scooters
yes you will prob have to remove one or maybe two laminates..............
Posted: Mon Feb 09, 2009 9:35 pm
by andylaw7
remove 1 to start off with and put a bit of masking tape on top of pickup and see if it scuffs otherwise it will be 2 laminates then loctite the grub screw when its perfect .
Posted: Mon Feb 09, 2009 10:09 pm
by Bufficus
Thanks fellas
Posted: Tue Feb 10, 2009 1:38 pm
by Special X
Is it the same with the LML LT coil?
Posted: Wed Feb 11, 2009 12:33 am
by Bufficus
Special X wrote:Is it the same with the LML LT coil?
Yes. I've done a couple of those. Got away with just removing one laminate from meory.
