all sorted... almost, gears!!
Posted: Mon Apr 26, 2010 4:59 pm
Neutral is almost non existent, when pushing the scoot it slips/jumps straight into first or second with no effort at all, you can also move the shifter (on top of engine) into first or second with one finger and hardly any pressure...
Cables are newly routed to stickies manual, with new inner/outers... all adjusted correctly, neutral (tho non existent) lines up with the marking on the handlebar. I lined up the (trunion holding) gear selector 90-degrees to gasket face in 2nd.
Im not sure whats causing this, im going to check the gear shifter/bar is seated correctly on the splines that protrude from the casings this afternoon, along with making sure the base plate for the gear selector is over hanging the gasket face, just read stickies again.
Is there anything i can check out before having to split the engine again?
