Extended exhaust manifold nuts
Posted: Mon Apr 26, 2010 1:45 am
by red ghost
Extended exhaust manifold nuts that can be wired up, can anyone share the overall length and wire hole size?
cheers
Re: Extended exhaust manifold nuts
Posted: Mon Apr 26, 2010 4:25 am
by Rude De
I use Small frame Vespa 7mm coupling nut that holds on the cylinder shroud from the head
Posted: Wed Apr 28, 2010 3:51 am
by vegansydney
Frank if your making some up can you put me down for a set or two. Not looking for favours, I have cash. Thanks! -Benji
Posted: Wed Apr 28, 2010 7:21 am
by Bilko
I think they vary depending on the exhaust
Posted: Wed Apr 28, 2010 9:19 am
by red ghost
vegansydney wrote:Frank if your making some up can you put me down for a set or two. Not looking for favours, I have cash. Thanks! -Benji
Yes I am and I like cash! :D
Just need length and hole size...
Posted: Wed Apr 28, 2010 8:04 pm
by cezeta
mine are 27mm long and with a 1.5 mm hole but the hole can be bigger
Posted: Thu Apr 29, 2010 8:13 am
by red ghost
cezeta wrote:mine are 27mm long and with a 1.5 mm hole but the hole can be bigger
And is there a hole on each flat, so 6 in total per nut?
Posted: Thu Apr 29, 2010 8:42 am
by joee
if your safety wiring them you'll only need 2? obviously on opposite faces ;)
Posted: Thu Apr 29, 2010 11:24 am
by red ghost
Posted: Thu Apr 29, 2010 7:06 pm
by cezeta
mine just have one hole all the way through
