Barrel set up??
Posted: Thu Apr 22, 2010 10:55 pm
Hi,still pretty much at the bottom of the learning curve and would like feedback on which would be your prefered set up of the two and why?
Cast iron 175
1mm base gasket and no head gasket giving:
160 degrees exhaust.
126 degrees transfer.
132 degrees inlet.
17 degrees blow down.
Piston level with bottom of exhaust port at bdc.
Squish 1.3mm.
Or no base gasket and a 1mm head gasket giving:
156 degrees exhaust.
122 degrees transfer.
136 degrees inlet.
Piston 1mm overhanging bottom of exhaust port at bdc.
Squish 1.3mm
I'm mainly interested to know what the timing differences will make if any and what peoples thoughts are on running this with a 5.2 final drive,42 mil clubby and 25mil phbl
CHEERS AL
Cast iron 175
132 degrees inlet.
Squish 1.3mm.
136 degrees inlet.
Squish 1.3mm
CHEERS AL
