Speedo Cable
Posted: Sun Feb 08, 2009 12:21 pm
by LI150
Following on from another thread I have discovered the problem of why my speedo on my LI150 Series 2 behaves eratically this is because the top of the inner cable is to thin for were it connects into the speedo.
Is my speedo worn :? Or is it just a case(which I suspect) I have the wrong cable. If this is so which cable do I need for my speedo..... Do I have a series 2 speedo and 3 cable or is this the other way round ?
Cheers Tim
Re: Speedo Cable
Posted: Sun Feb 08, 2009 12:24 pm
by bristolmod
S1 S2 and early S3's had speedo cables with a thin "square bit" at the top. This was made thicker on all later S3's.
Sounds like you have the wrong cable, and possibly a remade S2 speedo with the wider aperture??
Chris
Re: Speedo Cable
Posted: Sun Feb 08, 2009 12:33 pm
by LI150
The speedo has 26000 miles on it this made me think it was the early type.
Might sound a daft question but can I just use the same outer and buy a series 3 inner to see if it fits ?
Re: Speedo Cable
Posted: Sun Feb 08, 2009 12:59 pm
by bristolmod
I think they come as a complete item.
It could simply be the correct speedo and the correct inner, but either the end of the inner or the aperture is worn slightly allowing the cable to "miss" sometimes (normally a thin wrong inner won't allow the speedo to show any movement)
I recon the inner is correct but worn
Chris
Re: Speedo Cable
Posted: Sun Feb 08, 2009 1:52 pm
by LI150
The cable is brand new had it a while though........ On closer inspection as I found a old series3 cable I do have the correct cable and when I use a drill to turn the cable a strange noise as if something is catching can be heard from the speedo therefore I think its the speedo...........Thanks for the help and advice Bristolmod
Can anyone tell me how to contact Jem to have my speedo refurbed as I wish to keep this one
Tim
Re: Speedo Cable
Posted: Sun Feb 08, 2009 2:45 pm
by bristolmod
I'll PM you Jems Email addy
Chris
