chaincase cover
Posted: Wed Apr 07, 2010 9:31 am
by fajes
hi all,
I can't seem to get the chaincase cover to come off my Li150 III, it's like it's glued to the chaincase... :(
tried fumbling with the clutcharm, kickstart,... can't get it to move.
any tips?
Re: chaincase cover
Posted: Wed Apr 07, 2010 10:52 am
by Dimitrios_231
Use the double nut method,
(if the studs are long enough to tight 2 nuts),
to extract as many studs as possible.
Re: chaincase cover
Posted: Wed Apr 07, 2010 12:22 pm
by Toddy
fajes wrote:hi all,
any tips?
Try a gentle tap around the casing with a mallett it should only be the gasket , Daft Question but You have taken all the nuts off ???
Re: chaincase cover
Posted: Wed Apr 07, 2010 3:28 pm
by fajes
yes I've taken 'em all off! ;)
I tried gentle tapping, less gentle tapping and nearly tried hammering it!
I never had one stuck like this, normally a little fumbling pops 'em right off.
I was thinking of putting a big bolt in the oil drain plug and popping it off like that, but I'm afraid I'll damage the casing. :baddevil:
Re: chaincase cover
Posted: Wed Apr 07, 2010 9:32 pm
by rog60
Try pulling the clutch lever in with all the studs undone .......usually works.
Re: chaincase cover
Posted: Wed Apr 07, 2010 10:10 pm
by sean brady scooters
as rog says ,that usually does the trick...maybe try a large adjustable spanner on it to help.. :D
Re: chaincase cover
Posted: Thu Apr 08, 2010 9:30 am
by fajes
haah!!!
it came off! clutch lever, no result. gentle tapping, no result. a bend butter knife, result!! now I'm hoping the missus doesn't find out there's only five of 'em left... :smug:
Re: chaincase cover
Posted: Fri Apr 09, 2010 6:22 pm
by netweasel
fajes wrote:haah!!!
What I have done before is to fish some wire through the oil fill and overflow holes (or the oil overflow and drain holes), making sure to get in between the chain and chaincase cover, twist the ends together and wrap a towel around the wire and then pulled.
