bent layshaft
Posted: Mon Apr 05, 2010 10:07 pm
by martinr
anybody ever had a bent layshaft :?
Re: bent layshaft
Posted: Tue Apr 06, 2010 4:59 am
by Ruudboy
wow, that whole engine must be ready for the bin...
I just got a MB layshaft, it looks really nice!
Re: bent layshaft
Posted: Tue Apr 06, 2010 8:17 am
by netweasel
Check the layshaft needle bearing race in the endplate. If it is worn at all it can cause the layshaft to spin just slightly out-of-true and then the layshaft will then be off balance causing your rear wheel to wobble.
Either way, when you replace your layshaft, you should replace the layshaft needle bearing race in the endplate.
