T-Max, oil change to Synthetic.
Posted: Fri Apr 02, 2010 10:28 pm
Going to service my T-Max, and I've decided to run it on fully synthetic engine oil.
It takes 3.6 litres of semi synthetic oil as standard. So If I run it on high quality fully synthetic engine oil instead, then with its far better lubrication I was reliably informed that I would be able to run it with about half the amount of oil, and less oil means saving some money, but it will still have the very high quality lube in the engine.
So what I was going to do was run it with just over half the original amount, about 2 litres... Is it a good idea??
