engine out
iMotors
The frame is almost ready, time to start work on the engine...
that gunge will take some shifting :D
iMotors
Pics from this morning...
Now is time to start cleaning and inspecting
what did you use the gas torch for.....?
iMotors
Flywheel was really hard and have to apply some heat while mantaining tension with the puller and some help with the hammer... :baddevil:
ha ha,......just wondered if your stator plate survived the ordeal.... :D
iMotors
Only a bit not red glowing... :D
joespeed
heat nice! but not on the flywheel !are you changing it?
iMotors
To cut a long story short:
55 degrees celsius measured with the digital gun
NOT RED GLOWING
joespeed wrote:heat nice! but not on the flywheel !are you changing it?
looks to be one of the filso type with the cast boss ,i supose it depends how original he wants it
    Users browsing this forum: Google [Bot] and 11 guests
