Podtronic ignition/rectifier
Posted: Fri Feb 06, 2009 3:06 pm
Where can you buy a podtronic stator/ recectifier set up?
Is this the type that spanish serveta used to use? Do you still have a regulated 12volt ac supply or is everything run through the battery?
