BR8ES ?
Posted: Mon Mar 29, 2010 7:27 pm
by mickdale
can i use a BR8ES plug - i thought i was supposed to use B8ES?
guy told me the R stands for resister
cheers
mick
Re: BR8ES ?
Posted: Mon Mar 29, 2010 7:33 pm
by oldbiker
R stands for resistor 5000 ohms, needed for electronics using cdi types of circuits if you want to prolong the duration of the spark. a supressor cap uasualy has the resistor fitted.
Re: BR8ES ?
Posted: Mon Mar 29, 2010 8:07 pm
by mickdale
is it the wrong one for a sil electronic set up?
Re: BR8ES ?
Posted: Mon Mar 29, 2010 9:49 pm
by oldbiker
It will work
Re: BR8ES ?
Posted: Mon Mar 29, 2010 11:44 pm
by drunkmunkey6969
if you dont have a resistor cap....fit an R plug.
Re: BR8ES ?
Posted: Tue Mar 30, 2010 5:28 am
by mickdale
thanks for the help guys
ive got a ngk plug cap so probably needed a B8ES but if the BR8ES will work fine i'll use that
cheers
mick
Re: BR8ES ?
Posted: Tue Mar 30, 2010 10:23 pm
by RCA_Racer
5000 ohms NGK resistor plug cap plus 5000 ohms resistor spark plug ????
How will this affect the timing, as I am still convinved that when I used the above set up (I am running the smaller plugs as I have an MMW Cyl Head) , that when strobing this affected the timing by retarding the spark !!!!
Any thoughts on this ?
